does any of you guys running this size tire on the front pull your car. my allignment was perfect before. did you have to set it up with a negative camber to fix this if you have the specs please post them.thanks
275-40-17 on front alignment issues
I asked a similar question about a year ago. On rutted highways, my car will, sometimes violently, shift left to right. Wider tires just grip the road better than narrow tires causing them to follow road imperfections. I havent found a solution for it... Never tried adjusting my camber though.No F-Body right now
I am. A local Firestone place aligned my car to a toe of .02 and it fixed it. The spec is I think .12 to -.12 . Is was at .10 . The tolerance they say is allowable is too loose. Make them set it perfect.
Also running too high or too low of an air pressure will make it pull (to low) and dart (tramlin)(to high). The mfg spec is 30 psi.
A friend of mine with an 03 Cobra was having the same problem. He took it to the same dealership last Saturday. He had it at another dealership twice and the weeks before and they could not get it to drive right. (He doesn't think they aligned the IRS in the rear.) They spent 2 hours adjusting it but they got it right on the numbers. He said it drives perfect now. His quote was "I am proud of my car again."2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Im having a pulling to the right issue right knowOriginally posted by botlfeddoes any of you guys running this size tire on the front pull your car. my allignment was perfect before. did you have to set it up with a negative camber to fix this if you have the specs please post them.thanks2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
2000 red vw jetta,86k stock
