Originally posted by Christopherrr
Favorite Oil?
Originally posted by ChristopherrrWalmart Mobil1 5 quarts go for $23 bucks...$10 for a Mobil1 filter...$33 bucks!
Anyone a believer of Lucas?
Originally posted by Jeff 95 Z28Walmart Lawrencville Hwy and Lavista. I bought two 5 gallon jugs.
Originally posted by 97LT1Z28I think it's a 4-quart jug at Walmart.......
Hope you're not runnin it a quart shy.........
Advance Auto Parts is 4 quarts.
My ride is here: http://www.cardomain.com/id/1995RAMAIR
Originally posted by ChristopherrrAnyone a believer of Lucas?
My Boss swears by Duralube. I have seen it do wonders as well.
Scenario: His 93 Chevy Silverado, 350 engine, 250+k miles, Last winter, Starts truck with remote, runs for 15 minutes then shuts off after designated time is up, restarts with remote, runs about 10 more minutes til he leaves, drives about 10 miles to work, notices a slight knock, probably lifter, checks oil, low, doesn't even show on dipstick, pours 4 and some change quarts in until full, Starts truck again, looks underneath, oil pouring out, turns truck off, replaces worn and cracked oil cooler adapter ring seal and gasket, realizes he had the thing started for 25 minutes and drove it 10 miles with less than a half quart of oil in the pan, refill with oil and more duralube, drives home and sees 4+ quarts of oil on the ground where his truck was parked, continues to operate with absolutely no problems whatsoever till this day, 10+k miles later...
Does it work? Who knows? Do I use it? Yep, half quart, every other oil change.
Originally posted by lsdenginesI use mobile 1 in just about everything I drive. Filter, I like mobile 1 and k & n. On mine, I put together my own oil filter relocation kit, so I can use the BIG PH8A ford style filter. This is one area to NOT SKIMP on. Fluids and filters. They keep everything expensive alive.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
