If running boost, does anything need to be done as far as the brake booster is concerned? Or should I just switch to manual brakes? Drag racers, what are you guys running for brakes? Thanks.
power brakes and boost
never heard of anybody running manual brakes because of boost, as long as you have enough vacuum from your cam, you should be fine87 GTA: it's winter time, all tore apart
When you close the throttle and apply the brakes, there shouldn;'t be any boost in the intake manifold. Should work normally. Obviously there's no vacuum at all when your in boost, but you aren't going to be applying the brakes then anyway. If you want to brake stall the converter on the line, apply the brakes before you step on the throttle and the boost starts to come in.Fred
