I finally got my car tuned. 348hp at the wheels. Jeff (my tuner) said I could go ahead and remove my smog pump and egr. The egr is off, I was just wondering if there was any tips you guys could give me with the smog pump. Also, is there any one out there that makes aftermarket inserts for the ram air hood on a 97? thanks
Smog pump removal
Smog pump removal
1997 Formula WS6
43,000 miles, LT4 Hot Cam, 1.6 Roller Rockers, Ported Heads, Long Tubes, Borg Warner Built T56, Stage 3 Clutch, Aluminum Drive Shaft, Strange Engineering 12 bolt 4.11 Rearend, Nitrous Express wet shot.
2006 Saab 9-3 2.0T
18,000 miles, Stock, and staying that way (Daily Driver).Tags: None
Originally posted by 97formws6I finally got my car tuned. 348hp at the wheels. Jeff (my tuner) said I could go ahead and remove my smog pump and egr. The egr is off, I was just wondering if there was any tips you guys could give me with the smog pump. Also, is there any one out there that makes aftermarket inserts for the ram air hood on a 97? thanks
