Sometimes my car will misfire when given lots of gas,Sometimes it wont,any ideals
on and off misfire
on and off misfire
2000 red vw jetta,86k stock
Tags: None
134K plugs ,wires and optispark changed recently,As far as touble codes how do I check for that????,the check engine light isnt on,Sometime's the car will hesitate when given alot of gas other times it wont2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
mine hesitate like that when one of my plugs fouled out after i replaced them all 1month later. what plugs you put in?Originally posted by DHolmes134K plugs ,wires and optispark changed recently,As far as touble codes how do I check for that????,the check engine light isnt on,Sometime's the car will hesitate when given alot of gas other times it wont1996 Firebird Formula
have you tried cleaning your maf sensor? if you're stumbling on full power acceleration, it could be a dirty maf. spend $7 at oreilly's for can of maf cleaner and follow the instructions for cleaning the maf. it made a world of difference for my ragtop a few months ago- only took 10 minutes and my symptoms were exactly what u described for yours2000 Z-28 Convertible, neutral leather interior and neutral top, hotchkis STB, SLP Bowtie Grill, WhisperLid, K&N, cold air induction
Will auto Zone have maf cleanerOriginally posted by 00 Ragtop Zhave you tried cleaning your maf sensor? if you're stumbling on full power acceleration, it could be a dirty maf. spend $7 at oreilly's for can of maf cleaner and follow the instructions for cleaning the maf. it made a world of difference for my ragtop a few months ago- only took 10 minutes and my symptoms were exactly what u described for yours2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
I expect they do--if not try pep boys or advance--they should all have something similar. Then you take the MAF out, and spray thehell out of it from both sides, let it dry, then reinall. just dont actually touch the wires or screen. Literally takes only 10-15 mintues form start to finish--and if that is it (my bet is yes) you'll solve the problem.2000 Z-28 Convertible, neutral leather interior and neutral top, hotchkis STB, SLP Bowtie Grill, WhisperLid, K&N, cold air induction
All do that this week end,Ill post if I need any help but it sounds cut and dryOriginally posted by 00 Ragtop ZI expect they do--if not try pep boys or advance--they should all have something similar. Then you take the MAF out, and spray thehell out of it from both sides, let it dry, then reinall. just dont actually touch the wires or screen. Literally takes only 10-15 mintues form start to finish--and if that is it (my bet is yes) you'll solve the problem.2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
Well this might be a shot in the dark, but check to see if any of your o2 sensers are not arking out against any exhaust .I had it happen to mine it would stumble at a light or at an idle ,but when i gave it gas
,the stumble went away
just a thought--jack
JackZ28
K & N CAI
Kooks Header LT's
Free Flow Cat, Magnaflow Exhaust
Y-Pipe
Synthetic Fluids
If you are asking me -yes ,i taped up the wire and ziptide it away from the exhaust.I hope this is as simple fix for you as well its frustrating as hell
when your ride dont run properly. good luck--jack
JackZ28
K & N CAI
Kooks Header LT's
Y-Pipe
Synthetic Fluids
