Well im looking for some new rims i got 16" alloys but the tires have life left in them there 245's but they suck in rain im looking at some ws6 rims but can't deside on chrome/polished ones or the 02 ws6 rims i know if i go 17" ill have get speedo reprogrammed would i need spacers for them or anything?
Gonna buy Rims Any Ideals?
Your car came stock with either the base tire (235/55-16 = 26.1") or if the car had the optional RPO QLC Z-rated tires, a 245/50-16 = 25.7" tire. Look at the tire label on the door.
You only reprogram the PCM for the speedo if you change the tire diameter. The SS/WS6 17x9" wheels came with 275/40-17 = 25.7", so no reprogram there. You could even go to a 17x11" wheel and run a 315/35-17 = 25.7".
If your car had the 235's originally, you could run a 285/40-17 = 26.0" or just run the 275's with a 2% speedo/odometer error, or a little more than 1 MPH high at a true 60MPH.
The change over from the oversize rear hub diameter happened sometime late in the 1996 model year, so you may have to sand or grind the inside diameter of the wheel hub hole, as noted in the post above.Fred
+1 on the Speedlines. They're just my favorite wheel for Birds. ZR1s are nice also...but only on certain Birds.
Plain WS6 for a car not lowered.
Speedlines on a car that is.
Speedlines can look smaller than their indicated 17s on a car not lowered...but look more muscular than WS6s.
fikse rims look great on both 3rd gen and 4th gen fbody cars. they are pretty expensive though. i like the fm10.87 GTA: it's winter time, all tore apart
Originally posted by MunsonGTAfikse rims look great on both 3rd gen and 4th gen fbody cars. they are pretty expensive though. i like the fm10.
93 t/a A4 3.23s
99 Alfa Romeo 166 3.0 v6, red
97 3.8 v6 A4 camaro, hardtop
00 audi a6 4.2 40 valve v8
those rims you showed pics of are pretty sweet to. those are either the profil 5 or the fm/5. the fm/10 is just damn sweet.
Well i like American Racing Torque Thrusters what size should i get i wanna use my stock 16" wheels there 245/50/ZR16
They got alot 16" can't figure what one is what
http://store.summitracing.com/egnsea...5&Nao=10#rstop1996 Firebird Formula
