Any of the ports on either side of the intake manifold. Passenger side there are two connections, toward the back for the HVAC controls and the fuel pressure regulator. Drivers side there is a cluster of several connections for the EGR, PCV Vacuum (93/94 only, on the 95+ that's the Opti connection), and brake booster.
PASSENGER SIDE
Look on the right side, in front of the rear pair of injectors.
Shoebox - His is a 95. Yours will have a U-shaped hose that connects the end of the PCV valve to the connection toward the back, where his Opti vent is connected.
