Pod mounted vaccum gauge install
  • Pod mounted vaccum gauge install
    Just wanted to know where is the best place to tap this into a full vaccum
    on my 93 Z28
    Any of the ports on either side of the intake manifold. Passenger side there are two connections, toward the back for the HVAC controls and the fuel pressure regulator. Drivers side there is a cluster of several connections for the EGR, PCV Vacuum (93/94 only, on the 95+ that's the Opti connection), and brake booster.
    PASSENGER SIDE
    Look on the right side, in front of the rear pair of injectors.
    http://members.aol.com/Fredrick518/Photos/bkofint.jpg
    DRIVER's SIDE
    Shoebox - His is a 95. Yours will have a U-shaped hose that connects the end of the PCV valve to the connection toward the back, where his Opti vent is connected.
    http://shbox.com/1/opti_vacuum_conn.jpg
      Thanks fred for the detailed info. Lew
