Ok i just picked up a new camaro. Its a 94 LT1 Z28 with auto tranny. Tranny was just rebuilt 2k miles ago so i want to use it. Motor has 141k on it with some funky bottom end noise goin on, dont even feel like dealing with it. I have really been thinking of buying a used LT4 motor either off ebay or an online junkyard. LT4's came out of what cars? Corvettes only? They seem hard to find. Id prefer not to do the LS1 swap because of all the headaches, i just wanna drop something in with few headaches... Anything id have to change/modify to do this? This will bolt right up to the auto tranny right?
LT1 to LT4 swap questions
Take your LT1 engine, rebuild it with a set of well ported LT1 heads and matching cam, add all the requisite goodies like intake and exhaust upgrades, larger injectors, larger throttle body, PCM tune, etc and you will make about 125-150HP more than the stock LT4 engine makes. Or simply find an LT1 engine with significantly lower miles than yours and do the heads/cam swap. Check out these heads and cam packages as an example.
http://www.eportworks.com/lt1.html
There were also about 100 97 Camaro SS and about 30 97 Firehawks built with the LT4 engine, but it isn't likely you'll find one of those engines for sale.Fred
I would imagine all LT4s were 4 bolt mains. What you says is considered true for the LT1 engine.Originally posted by Joe 1320Correct me if I'm wrong, but didn't the LT4 block from the Vette have 4 bolt main caps where the F-bodies received 2 bolt mains?Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
All F-bodies received 2 bolt engines in the factory. In the rare instance a car was short blocked or long blocked under warranty, the replacement motor had 4 bolt mains. I've been told all warranty replacements were 4 bolt.
I have a 4-bolt motor out of a 95 Camaro in my garage. The serial plate on it is blank. It used to have a sticker on it where the serial number is normally stamped. The original owner of the car told me that the dealer had to replace the motor under warranty, so then it all made sense.Tracy
