Door lock knobs %^&*%+^&#$
  • Door lock knobs %^&*%+^&#$
    I just spent all day putting all new speakers and Dynamat in my car. I had the hardest time getting the lock knobs on, and I finally quit trying because it is getting dark here (EST +8 hours). I'll take the door panels off again New Years day. What I would like to know is what is the best method for getting those little suckers on?
    99 Silver Z28 A4, T tops, ZR-1 wheels (SOLD)
    There is a trick to it. Once you know the trick they snap on in seconds.
    It's a secret.
    Here goes... the rod is bent at a 90. The bent part goes in the hole in the knob then the knob just snaps over the rod with a gentle push.
      ....Right. what i do is: put the door lock rod through the hole opening in the inside door panel handle trim , then just place the lock knob on and firmly snap it back on.
      -Ryan-
        It also helps if you make a hook or something to reach in back of the lock rod to help pull it toward you as your snapping them on.
        2002 V6 Firebird (wifes)
        2013 GMC Sierra (mine)
        2011 Cadillac CTS4 (wifes)
          Or you can just slide a screwdriver behind the lock rod to keep it from pushing in a you snap the knob in place.
          Tracy, 97 Formula, pretty much stock.
            I loosened the door handle trim piece and made a hook with a coat hanger to hold the rod as I snapped it in. Thanks to everyone (except TraceZ, may he have to change spark plugs soon).
            Happy New Year
              Use needle noses and hold the rod. Goes on within seconds. I have removed my door panels dozens of times and it works perfect.
              Eddie
              2000 M6 Trans Am
              Tune+exhaust=344WHP
                Whats the big deal i have done it about 5 times. You cuss it a bit an it goes in.
                Blazer
                  I've never had to hold the rod with anything. A gentle push and they snap right on.
                  I must be the lucky one.
