Found two of these bearings stuck to the magnet on the oil drain plug. Can anybody identify what they came from? Engine runs good with no strange noises.Approximately 6mm by 1.5 mm
Bearings in oil
Good eye joe. Dang.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Its back together with a used rocker. I've been using synthetic since I got it, but the insides of the valve covers had some crud.
Good thing I noticed the needle bearings. if the lifter went, then a valve would go, and then a piston etc.
There wasn't any metal fragments on top of the head.
The pushrods were all good.
99 Silver Z28 A4, T tops, ZR-1 wheels (SOLD)
I have heard of LS1s having rocker arm problems. It makes me wonder if I should change mine.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
