hey guys im looking to buy a set of springs of someone cool right? i dont know you all tell me. i have a 94 v6 A4 the springs are coming out of a newer LS1 will these work on my car or not? if it makes any difference very soon im swapping a LT1 M6 into mine. Thanks guyz
Eiback Pro-kit Springs
will they fit? Yes.
Will they work well? No.
Not only are they are harsh spring to begin with, but the rate is taylored for a much heavier v8 motor. The front end will ride like a brick and will sit higher than what you anticipate. Remember...... the spring is designed to give a certain ride height based on weight.
then when you swap in an iron LT1, the front will drop due to the increased weight.
ok but when i put the LT1 in will it put it lower then original height or or stock because its setup for the LS1 which is obviously heavier (i hope im not confusing you) what if i leave me stock v6 springs will it drop casue they wont be used to the heavy load (knowing they will wear down quicker)94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
so pretty much just wait untill i can buy brand new ones for a LT1 specifically as opposed to the ones with the LS194 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
Why swap the springs now? When you swap in the LT1, you have to completely replace the K-member. Why not wait until you have the front end apart to swap the springs?Fred
well gesh i guess my question at the start came off wrong hahah
but thankyou i was just wondering if it would be a good idea or not to buy the springs at a cheap price and put them on there eventhough they are for an Ls1. but thankyou all for your help i really appreciate it
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
Personally, I wouldn't put the Pro-Kit springs on a shopping cart. I tried them and hated them. Terrible ride quality. Deifnitely were not compatible with the QA1/HAL adjustable shocks.Fred
alright well im not rich and my funds are kinda sluggish right about now. but my rear right shock is just about shot so soon im gonna need to swap them out and i see no sense in doing them oem swap if im gonna lower it later. so what do you think would be the best bang for the buck on springs and shocks. thanks for the helps guyz94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
just replace the stock shocks for now and when u do get more funds to do the LT1 swap, do the springs at the same time. stock rear shocks arent that much if i remember right.2009 Honda Civic EX- the daily beater
