95 Z-28 with a dealer-installed GM model VSS-150 Security System. This vehicle is driven infrequently, and the alarm system will run the battery down (to the point that it won't crank) if the car is not driven for a few weeks. This sytem cannot be turned off -- all you can do is put it in the standby mode -- but it continues to drain the battery in that mode.
I pulled the fuses for the alarm system, but that triggers the "starter disconnect" mode. Is there a chance somebody has either a wiring diagram for the VSS-150 (it's not in the shop manual) or some advice about which wires to cut to disable this system.
Thanks,
Skip
Thanks,
Skip
