I have an issue that I believe applies only to 83 and 84 L69's with AC. I ordered my 83 L69 without AC. I just finished installing a complete factory AC system from a donor 83, non-L69 car.
My problem is that the compressor wiring on other engines are different from an L69 and since they don't have electric fans, I also want to control the electric radiator fan to the L69 factory specifications. I could rig it to work, but I want it to appear OEM.
I have two connectors located between the evaporator housing and the distributor. One terminal is hot when the AC is on. Another operates the fan when grounded. I am guessing that between those two terminals and the other terminals, they control the compressor and the fan.
Does anybody have an L69 w/AC that could shed some light on what these connectors connect to? Since the L69 had a late intro in 83, my 83service manual doesn't cover these differences in the wiring diagrams. Maybe a page or two from an 84 service manual AC wiring diagram might do the trick.
Thanks!
Larry
Thanks!
Larry
