ok guys so i was working on my new motor this weekend after the swap just going over everything and i noticed that i have one alum. head and a steel head. the way i figured this out was i was using a magnet and it got pulled to one head (steel) and not the other (alum.) can someone please explain why this would be? anything factory? some dummy could only afford one head? should i worry with 103k? is it gonna blow? when is armaggedon? will i fall in love one day? ahhahahahahahah sooo many quesitons in this world.
One Steel head one Aluminum Head?!!?!?!?!?! none2
94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
1992 Convertable RS 305/700r4 <<<Just a Beater
GOT PSi?
Good Cause Your Gonna Need It!!!Tags: None
That's some shoddy work someone did on the car.
It will live. It's just not the best scenario.
TEHE would anyone happen to have a set of heads preferably aftermarket for sale cause if im gonna have to pull this thing apart its gonna be worth it.94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
One side may has more power than the other.
Did you notice the car pulling to one side when accelerating?
no it seems to pull pretty straight i mean i havent launched off from the line cause im still runing the V6 rear.94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
Why do you prefer "aftermarket" heads? The LT1 heads (aluminum) can be ported to produce upwards of 500 flywheel HP. You just need a second aluminum head, to match the one you have. Note that there are two very different aluminum head castings used on the LT1's, so you have to match the casting number.
Interesting thing is a stock iron head flows better than the stock aluminum heads, but the extra heat retention may not allow as much timing advance as the aluminum head. Might be a bit difficult to tune.Fred
ok fred so your saying i need to find the number on the alum head? where could i find that? and when i find that and if i gave you the number could you help me find another head? and that would be crappy cause one head would have 103 and who knows what the other head will have. if i swap out the steel head should i rebuild the alum when i replace the other one?94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
Without going up in the loft over my garage, and looking at my old LT1 heads, I can't give you the specifics. But I believe the numbers are on top of the heads, under the valve covers.
Here is info on the different LT1 heads:
http://www.camaroz28.com/forums/showthread.php?t=427346
oo ok so like rob said i should be ok i mean its not a built motor or anything just a stocker i only plan light mods for it its my DD right now. so i shouldnt really worry about it?94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
The casting number is the long, vertically oriented number in this pic. This one is known as a 643 (10207643).Originally posted by 1slo_camarook fred so your saying i need to find the number on the alum head? where could i find that? and when i find that and if i gave you the number could you help me find another head? and that would be crappy cause one head would have 103 and who knows what the other head will have. if i swap out the steel head should i rebuild the alum when i replace the other one?
ok ok ok so maybe i was dumb and the one side i was hitting the block instead of the head and didnt realize it cause it was from the bottom that i noticed. why would it have alum. heads on both sides? that wouldnt be because it was a vette LT1? it seems to have more power then any other LT1. well i raced a 96 bird with intake full exhaust, gears, programmer, and it was an A4 and i pulled two cars on him. i raced a new EVO (12.6's) he has intake exhasut dyno tune boost controller short throw and a stage 3 clutch. and he only pulled a fender at 120 plus. now he couldve been a bad shifter but my car really surprised me to stay with him that long and i only have intake and muffler single outlet at that. why is this car soo much quicker also with a v6 rear i believe 283 open? someone please correct me if im wrong.94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
