Is there such a thing as an aftermarket programmer for fuel economy for LT1 Camaro? I have a 1997 Z28 with a 6 speed manual tranny. If such a programmer exist what kind of fuel economy could I expect? Any suggestions would be great.
fuel economy programmer for LT1 Camaro?
i got the same setup with a v6 rear and ill pick up 23-25 mpg highway at about 2k rpm cruisin like 8094 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
You can get 4.10s in that and it still get 23-25 mpg at highway speeds 6th gear pwns.Originally posted by 1slo_camaroi got the same setup with a v6 rear and ill pick up 23-25 mpg highway at about 2k rpm cruisin like 801996 Firebird Formula
He has a V6 car with a LT1 swapped into it, hence the 6-speed and the V6 rearOriginally posted by 1slo_camaroi got the same setup with a v6 rear and ill pick up 23-25 mpg highway at about 2k rpm cruisin like 80
Red 97 V6 (STOCK), Black 96 Ram Air WS6 M6 5.0 PRO, skip shift delete basicaly stock, for now . . .
not a clue on that one, if anything I would think the V8 rear would be stronger, but I don't know, someone with more knowledge will chime in I'm sure
But we are kinda diverging from the original thread, to the OP: as said above shifting is the best gas saver and I think people have a little mileage increase when upgrading the ignition system MSD and what not, there was a thread on one of the other forums asking the best RPMs for fuel economy, if i c it I'll post a link. . .
But bottom line is f-bodies aren't known for sipping gasRed 97 V6 (STOCK), Black 96 Ram Air WS6 M6 5.0 PRO, skip shift delete basicaly stock, for now . . .
You know, I remember seeing advertising for a Hypertech programmer that was supposed to be for mileage...not sure if they make one for your car or if it even really works but you might want to at least check out their website... www.hypertech.com i would think that it would cost too much money to justify any fuel savings though.2006 Saturn Ion Redline
2003 Mits. Eclipse Spyder
no not at all its only a one-legger burn and has no traction off the line. the story behind that is when i did the swap i went to change the gear oil and noticed some cracked and busted teeth so i have to run the v6 rear untill i can get my posi rebuilt its gonna cost me 700 thats everything new except the housing then im ordering a big bear brake kit for 1300 so im
till i get all that together which is gonna be about two or three months lol sorry for the confusion
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
my bad....just out of curiosity is there an advantage to the v6 rear?
