On my way home from work, I noticed the car started shaking terribly. It began to lose power and was shaking worse at low RPMs. As the RPMs go up, the shaking seems to go away, but still down on power - which I would assume would be running on 7 cylinders? I can hear something detonating/popping in the headers, which I'd assume is due to a misfiring cylinder's raw fuel loading up the headers?
It's too hot to be touching the plugs and wires yet, but they all look ok and connected well. I did a scan and obviously see KR, but also noticed that the O2s are not even close to normal - both sides. I don't see any jumping, they are just at a stagnant .25 to .5. I attached the scan, in which it hit closed loop about half way through. I really hope it's just a plug wire. Thanks for any advice.
BTW, I renamed the attachment from csv to txt because it wouldn't load a csv file.
