hey guys i need real help here my car is running rich my 02s are brand new and MAF is brand new i really need to get my baby tuned. but i need the software. does anyone have this software that a shop can use to tune my car or does anyone know a shop on the east coast that can tune my car
A Tune
If I were you and I have done it before I would get the cable and get someone like PCM for less to make you a tune and send it to you. It's a piece of cake to load. If you get the software to tune it there are so many parameters that if you don't know what you are doing you won't know how to adjust it right.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
You can get a mail order tune that should come relatively close to what you need - but watch out, there's a chance it may not be. The more wild go, the more the mail orders will be off. My "mild" cam and head package were a little too much for a mail order tune...it's running terribly rich, but it is definitely better than the stock tune.
Some mail orders are: www.pcmforless.com or www.madz28.com94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
Brian at PCM for less will work with you on the tune. If it is running rich tell him and he can tweek it for free and send you a new tune.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
well thats what happened is the guy that built my motor got me a mail order and i just dont like the way its setup. also i would love for someone in the area if any i would even be willing to drive it i.e Fred or Ken since im in Va/Md to drive my car it seems like at lower RPMs between 1500 and 2000 it wants to be stupid and from time to time it breaks up top-end. im planing on changing my ign. coild and plugs just since they will be easier then changing opti just for a check. and by stupid its like starting out in 5th gear how it wants to jump and jerk. and yes it is running richOriginally posted by Craig 94 TA GTYou can get a mail order tune that should come relatively close to what you need - but watch out, there's a chance it may not be. The more wild go, the more the mail orders will be off. My "mild" cam and head package were a little too much for a mail order tune...it's running terribly rich, but it is definitely better than the stock tune.
Some mail orders are: www.pcmforless.com or www.madz28.com94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
1992 Convertable RS 305/700r4 <<<Just a Beater
GOT PSi?
Good Cause Your Gonna Need It!!!
If its got misfires and/or exhaust leaks before the O2 sensors, its going to run rich. If its got a "big" cam, its going to be very hard to get it to idle right, without blowing a lot of fuel out the exhaust. If you don't have cats, its going to smell rich even if it isn't.
Need more info about the engine. What cam are you running?
Who did the "mail order" tune?
What brand O2 sensors are you running? Are you sure the wires haven't been burned by the headers?Fred
the cam i believe its the cam out of a LT4 Hotcam kit. there is a small leak on each of my headers. the 02s are bosch i believe i got them from advance auto. i have cats but i think the guy prior to me gutted them. im hoping after the holidays to get my catback and a magnaflow high flow. i ran it on my v6 and loved it so im hoping to get the same with the 383. i will try to find my cam card and all the paperwork from the motor build and get it to ya94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
Based on feedback from posts on other, more active forums, the Bosch O2 sensors have caused problems in a number of cases. There's a very strong consensus that you should use only OEM AC/Delco (now Delphi) O2 sensors.
If you have header leaks, its going to cause it to run rich. Also, as I said, misfires make it run rich. Couple those problems, and you could be pouring enough fuel into the engine to cause it to foul plugs and wash the lubrication off the cylinder walls. Check your oil to see if it has thinned out and smells like gasoline.
Fix the headers leaks. If you don't know the condition of the ignition components, particularly the plugs and wires, replace them. Use the NGK Iridium plugs, probably a TR6 would be best. Gap them correctly. I like the MSD 8.5mm SuperConductor wires. Leave the coil alone. I swear that the MSD coils seem to fail more frequently than the stocker.
You also need to use scan software to data log the PCM. You can get FreeScan for (surprise!) free. TTS DataMaster is free for the first 20 uses., All you need is the correct cable. AKM Electronics can help you out there.
http://www.ttspowersystems.com/
http://www.andywhittaker.com/
http://www.akmcables.com/
Something like a faulty coolant temp sensor could be causing the problem. The data log, or even a hand held scanner will tell you if that's the problem. IF you run the data log, I'll take a look at it for you.Fred
Who did the mail order tune? I got a madz28 tune and am not at all pleased with the performance, or the customer service (when I get a response).Originally posted by 1slo_camarowell thats what happened is the guy that built my motor got me a mail order and i just dont like the way its setup.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
i believe he got it from PCMforless.com he is apparently real close with the guy he deals with them alot!!!94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
hey fred dont mean to be a dummie about this but i downloaded the program from TTs and is this the correct cable:
OBDI-style USB/ALDL Cable, fully tested, molded connector (rectangular style 12-pin)
Fits up to -1993 Corvettes, -1994 F-body, -1995 B-body, and many other 1984-1995 GM vehicles
for like 90 bucks?94 V6 A4~~LT1 M6~~383 M6 13.1 @ 109 with a 2.1 60' Sold/Stripped
94 Z28 383 A4 Sold
75 Chevy~~~~ SOLD
GOT PSi?
Is the cable from AKM? If so, it will be correct. The main difference in the cables is the 16-pin connector used on the 95's, so that doesn't affect you.Fred
