I tried to get the car smogged on Saturday and it failed as a gross polluter - literally 8x the limit for HC (2.5x gross polluter limits). CO% was borderline but failed as well. NOx was fine. It turns out, the motor just started to miss and was missing on the smog dyno. My question is, a slight miss going to cause this high HC count? The count is unbelievable - has anyone had a smog when it was missing (it not missing that bad but enough that it shakes under load). Here are the results:
15 mph
HC max: 83
HC gross polluter: 269
HC measured: 686
CO max: 0.48
CO gross polluter: 1.98
CO measured: .66
NO (PPM) max: 689
NO gross polluter: 1907
NO measured: 382
25 mph
HC max: 48
HC gross polluter: 219
HC measured: 526
CO max: 0.46
CO gross polluter: 1.96
CO measured: .53
NO (PPM) max: 706
NO gross polluter: 1707
NO measured: 335
The cause of the miss was a plug wire touching the header and the core arching on the header.
15 mph
HC max: 83
HC measured: 686
CO max: 0.48
CO measured: .66
NO (PPM) max: 689
NO measured: 382
25 mph
HC max: 48
HC measured: 526
CO max: 0.46
CO measured: .53
NO (PPM) max: 706
NO measured: 335
