Originally posted by Craig 94 TA GT
Is the PCM pulling its max knock retard all the time?
Were your start up enrichment tables changed?
Possibly a bad batch of fuel?
An exhaust leak can't cause engine knock directly, but if you have a leak, and the fresh air is getting drawn into the system, that would cause your high block learn counts, the o2 sensor sees this is being WAY to lean.
Make sure its knock and not a small leak just popping at you every once in a while.
Knock counts are going up all the time just idling?
That would be a sign of a good spark knock, assuming your fuel is good for the compression you have.
cheap test: Throw a full bottle of stabilizer or octane booster in there,
If the knock count goes down or the retard lessens, its real knock, and that could get nasty with all the different problems you're experiencing.
Whats your base timing and fuel you use?
150-160 IAC steps at 60 mph... how much cfm does your engine suck?
Mine takes a max of 99 steps(that i can see) on the scanner.
If you got a BIN file of the ecu send it to me if you want, i'll look at it.
