how much more power can be gained? im looking to more power. im looking to get a set of heads but not for a while. i have the hotcam now.
hotcam vs cc306
Id say wait for a heads/cam combo instead of a cam now, and heads later. I think the Comp Cams XFI-406 would be a better choice than the cc306. Both are much more agressive than the hotcam.1996 Arctic White Z28, A4, K&N CAI, TByrne MAF ends, BBK Twin-52mm TB, TB Bypass, SLP 1 3/4" Shorties, Richmond 3.42's, Dynomax Bullet Muffler W/Turn Down, BMR Adj. Panhard, EIBACH Pro-Kit, AFS ZR1 Wheels W/17x11" out back!
don't get a 30697 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
there are way better cams out man. my first instinct (like you) was 306. After researching and talking to a lot of people on here, guys at comp cams, and a custom builder, I got a cam designed for exactly what I wanted.Originally posted by thomasany particular reason
Call comp, they'll put you through to somebody that can help you and they'll do a custom grind. They take a lot of factors into account. 306 is too off the shelf. Might not do exactly what you want.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
to go in)
