My 97 TA, in the dark I can see sparks jumping from the body of my coil, to that thick metal frame that goes around it. Plus, along the routes of some of my 8mm wires, I see sparks jumping out the sides of them.
I would assume any spark I see is not making it to a spark plug, and thus causing a misfire. Which isn't good right?
I should see no sparks correct?
I just bought a over the valve cover wire loom and wire set I plan on putting on, hoping this will help the problem, I guess maybe I have the wires routed too tight?
What would cause the coil to shoot sparks out the side?
Thanks for your help guys!
...Tim
...Tim
