anybody running prothane mounts? and what about running a solid type mount on an auto trans and stock type mounts at the engine?thanks
mounts?
mounts?
1994 formula trans am LT-1,ED WRIGHT tuned PCM, urathaned rear lca's,new factory rear springs,rear replacement shocks,functional ram air 4 inch cowl hood,hiflo cat,3 inch single into hooker hiflo muffler,2.5 out dual,air foil,underdrive pullys,edelbrock torque arm,drag bags,6T MSD,MSD coil,new built A4,2200conv.massive trans coolerTags: None
the mount question
i have broken a new stock mount in a very short time i am fishing for folks that are knowledgeable on running a prothane or urathane mount on the trans and stock types on the engine.1994 formula trans am LT-1,ED WRIGHT tuned PCM, urathaned rear lca's,new factory rear springs,rear replacement shocks,functional ram air 4 inch cowl hood,hiflo cat,3 inch single into hooker hiflo muffler,2.5 out dual,air foil,underdrive pullys,edelbrock torque arm,drag bags,6T MSD,MSD coil,new built A4,2200conv.massive trans cooler
I've been running an Energy Suspension polyurethane tranny mount on my car for 12 years, and the stock rubber motor mounts. No problems at all, even when subjecting the setup to 800HP/800 ft-lb. The same ES mount has been used under three different trans setup - original T56, TH400 and TH400+Gear Vendor O/D. The thing is indestructable.Fred
mounts?
thanks! that kinda says it all!1994 formula trans am LT-1,ED WRIGHT tuned PCM, urathaned rear lca's,new factory rear springs,rear replacement shocks,functional ram air 4 inch cowl hood,hiflo cat,3 inch single into hooker hiflo muffler,2.5 out dual,air foil,underdrive pullys,edelbrock torque arm,drag bags,6T MSD,MSD coil,new built A4,2200conv.massive trans cooler
