hey anyone out there run or are running a heat sink type trans cooler? what is your opinion of them? ie do they work well. thanks
trans cooler
trans cooler
1994 formula trans am LT-1,ED WRIGHT tuned PCM, urathaned rear lca's,new factory rear springs,rear replacement shocks,functional ram air 4 inch cowl hood,hiflo cat,3 inch single into hooker hiflo muffler,2.5 out dual,air foil,underdrive pullys,edelbrock torque arm,drag bags,6T MSD,MSD coil,new built A4,2200conv.massive trans coolerTags: None
Question, Why do you feel you need a Trans cooler?Originally posted by DRAGINhey anyone out there run or are running a heat sink type trans cooler? what is your opinion of them? ie do they work well. thanks
Either way you can run a radiator type that mounts in front of the Radiator. You simply bypass the radiator connections and plum it through.Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
If you are talking about the deeper trans pan with ribs, remember that they sit another half inch or so lower, on a car that is already pretty low- I would go external before I went the deeper pan, if I felt the need-2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
"Black, the fastest color"
i just had 2 replace a radiator and am
on my performance tranny builder to rebuild my 4L60E. i lost 3 and 4 for no specific reason. it is a known fact these trannys do not live in performance situations. i was told extra trans cooling would help the new trannys life. if you have ever pulled your radiator or tried 2 get to the front of it or the condenser the way it leans 2 mount a traditional i feel the only place i want 2 mount it is the 4" X 29" inch opening that all the air comes thru from the bottom of where the bumper skin mounts and the core support at the bottom of the condenser.maybe i'm just a woos' but if these radiative coolers really work i intend 2 get one.the tranny builder said just get a cooler of some kind.i already have an aluminum + 2 quart pan on the way 2 help in cooling by volume.
How big of a stall are u planning on running? A beefed up trans does not cause a big diff. In operating temp, it's more the stall you run which will hurt ur trans! You can bypass the radiator lines and run them right through an external cooler like mentioned above! It will sit up right against the radiator and will help cool your trans.Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
My car was originally an M6. When I bought my Griffin radiator, I had no reason to buy one with the tranny cooler built in. When I converted to the TH400 with a high stall converter, I needed a stand-alone cooler. The shop selected a Perma-Cool fan assisted fin-tube cooler. It's mounted in the drivers front fender, where many people have the filter for their CAI. Keeps the tranny nice and cool, under all conditions, including 800HP/800ft-lb pulls with a 5,000rpm flash stall on nitrous.
[EDIT]
Added photos:
injuneer...
thanks for the option of placement of a traditional type cooler. i feel better running them as i have always run them without the fan in the past and never had any problem. your photos are perfect to set me on the path.i appreciate your help and your time.1994 formula trans am LT-1,ED WRIGHT tuned PCM, urathaned rear lca's,new factory rear springs,rear replacement shocks,functional ram air 4 inch cowl hood,hiflo cat,3 inch single into hooker hiflo muffler,2.5 out dual,air foil,underdrive pullys,edelbrock torque arm,drag bags,6T MSD,MSD coil,new built A4,2200conv.massive trans cooler
That's a pretty tidy looking set-up. how do you control the fan, a temp-switch?2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
I put a trans. cooler a few years back like Fred's but put it in the opposite side and opened to black plastic block off cover so the air would come in.
It just under the right headlight.
