I don't know if you all remember the post I had about my TCC, idle, radiator fans and engine miss problems, but they are fixed. All it was was a little wire.
One of the two wires going to the coolant temp sensor on the water pump was grounded out. The wires were running between the intake tube and thermostat housing and one of them was touching one of the bolts for the housing. I moved the wires, taped them up and now the T/A is running perfect again!
I knew that something was wrong with the coolant temp sensor, just had to figure out what. I have never been so happy to find out I had a wiring problem, lol!
At least you stated that you weren't sure about things and that's a wise disclaimer.
