A 94 camaro radiator should fit in my 83 trans am right.
Radiator question
The LT1's have some odd supply and return hose connections, because of the "reverse flow" cooling system. Couple that with the fact that the front end structure of the 4th Gen is totally changed from the front end structure of the 3rd Gens - total suspension and unibody redesign - and I'd say you need to make some measurements before jumping to that conclusion.Fred
It's pretty close. The LT1 radiator is about 2" narrower than the 3rd gen radiator. It's also about 1/4" thicker. Height is the same. Inlet hose size is the same, it's a couple inches lower than the third gen. Outlet hose size on the lt1 radiator is smaller (by 1/4") and is a little higher. I notice in your sig that you're swapping in an lt1, so the size and locations of the radiator hoses should match up with what you're trying to do. Good luck with you project, and keep us updated!Dave
Independent AMSOIL Dealer
94 Z28 M6 - exhaust, K&N drop in, and lots of plans...
DD 98 Ram 2500 CTD (might be faster than my Z!)
I don't own a fbody, but was going to say that they would likely be quite different. Judging by the above, I think with some parts swapping/fabricating you'll be able to complete the swap without any major issues.Originally posted by darkhorsecustomsIt's pretty close. The LT1 radiator is about 2" narrower than the 3rd gen radiator. It's also about 1/4" thicker. Height is the same. Inlet hose size is the same, it's a couple inches lower than the third gen. Outlet hose size on the lt1 radiator is smaller (by 1/4") and is a little higher. I notice in your sig that you're swapping in an lt1, so the size and locations of the radiator hoses should match up with what you're trying to do. Good luck with you project, and keep us updated!
