So I have my car back from the transmission shop.
I had the SPEC Stage 2 setup with Al flywheel that has been sitting in the garage for 2+ years installed along with the transmission rebuild and completely new clutch hydraulics. The hydraulic setup came complete and was "pre-bled".
I only have about 50 miles on everything right now but there are a couple of things.
There is a VERY strong vibration coming through the clutch pedal. It speeds up and slows down with RPMs. If I push in the pedal about and inch it goes away. The new clutch is also very rough when it engages. Right now, there is no such thing as easily letting off the clutch to start moving, you have to give it some revs or it will shake the car apart.
This is the 4th clutch I have had in the car (Original for 75K, SPEC stage 2 for <10K, Stock replacement for 32K) and I have never felt that vibration before. I have also never had a clutch engage so harshly.
Both the trans shop and SPEC say give it some time and let everything break in. The trans shop is blaming the harshness on the Stage 2.
I'm not convinced.
Am I imagining things?
What else can I have them check?
I'm not convinced.
