He got more than one clutch disc. What are the odds that they're all bad? I guess there is a slim chance that he got repeat bogus discs, but it's not very probable.
With Spec anything is possible.
I did not have the harshness/vibration the first time I had a SPEC in my car. It was smooth and worked fine, it just went from "new" to "worn to the rivets" in 10K miles.
The chatter does seem to be improving slightly (or maybe it's me getting used to babying the clutch...) but the vibration is not improving at all. I've got around 200 miles on it so far.
Originally posted by raroz28
I'm convinced that your issue was with your flywheel.
I am starting to think that too. I still have the stock flywheel. It's in good shape and I have had thoughts of swapping it back in to see if it helps. I remember someone posting that the flywheel needs to be resurfaced in a particular way. How is that?
Not sure if you already mentioned it, but I have a few questions?
Are you sure the flywheel is properly weighted (externally balanced) for the LT1?
Does the vibration remain constant when the clutch is depressed (disengages the clutch disc from the engine) and released?
Did you properly torque the flywheel bolts so it is sitting flush and not canted?
Did you replace the TO bearing with a solid or needle bearing design? (I used a solid bronze bushing)
Was the clutch installed with the correct face facing the PP and flywheel?
Vibration is NOT normal, and thinking it is until "broken in" is absolutely false. Driving like this can destroy you bearings quickly, so fix it. After I put mine in, it was smooth as silk.
The Al flywheel was purchased as part of a set from SPEC for the LT1 so I assume it is properly balanced.
No. If I depress the clutch pedal about 1 inch the heavy vibration goes away. At that point, the clutch appears to be still engaged or engaged enough that it is not slipping.
This was done by the trans shop so I assume it was done correctly.
I assume you mean pilot bearing? Yes. The pilot bearing was replaced with a needle type from NAPA. The SPEC clutch setup came with a new TO bearing as well.
Again, this was done by the trans shop so I assume it was done correctly.
Sorry...but I think I'm out of my league on this one. I don't know enough about transmissions to give any more advice...sounds like you looked at all of the obvious. You may need to get another shop involved to proof the work of the first.
However, I've heard the same sporadic issues about SPEC. That's why I went with RAM.
And by the problem I mean the POS SPEC clutch and by fixed I mean removed and put back in the box where it belongs!
The shop checked everything again and could find nothing wrong. Since they had pulled the trans yet again to make triple sure everything was good and I suspected the flywheel was bad, I had them put the old, stock clutch, PP and flywheel (resurfaced) back in.
It now runs smooth, all vibrations gone.
I once again have a $1000 door stop with the SPEC logo printed on it.
I apologize to those who like SPEC products but I don't think it's a accident that SPEC is a four letter word.
Anybody interested in purchasing or trading for a slightly used LT1 SPEC stage 2 clutch setup complete with Al flywheel?
On a positive note, at least it's fixed. Makes me glad I avoided SPEC and went with all RAM products...the Mustang crowd steered me in the right direction for a change (LOL).
That's funny because I used RAM back when I had a Mustang and had no problems with them.
I installed a SPEC II in my '97. I absolutely hated it from day one. There is an excess amount of feedback and the clutch grabs. From what I read, the success of the product is inconsistent at best. I will never use another one nor recommend it. I didn't bother talking to the company and getting a new one...the time and effort to use the same piece of junk isn't worth it. I would have been better off picking one up at Autozone.
'77 K5 rock-crawler project
Thomas Jefferson
