Recently I have purchased a 1994 T/A in need of some TLC.
Alright.
I purchased the car, filled up the fluids/tires/etc. While driving away put down the driver window, went down at a normal speed. Tried to get the passenger side down, it didn't budge. Later on after replacing the battery, I was watching TV and saw the weather channel predicted thunderstorms, went out to go put the windows up. Driver side didn't want to go up, accidentally tapped 'down' the passenger switch and i heard it go down an inch. I proceeded to find that now the passenger worked and the driver side did not.
Asked if the former owners knew of it, they said they had both motors replaced since they have owned it, which is 1999-05, when they stored it.
What does this sound like to you guys? If there is any more details I can give let me know.
Don't worry, I put a tarp over her and cinder blocks around the corners.
EDIT- I might as well ask, is there anything I can do in terms of just getting the window up so I can drive it in questionable weather?
Alright.
