I've noticed in pics of other LT1s that in a couple of places there is a heat/foil wrap around hoses and cables. My car doesn't have this. Does anybody know where I can get some of this and is this important to have?
heat wrap replacement
Shoebox's harness photo will show you where the stock harness has wrap. Those are the location the engineers thought might be exposed to excessive heat, and needed heat wrap protection. Mine has been removed in a couple locations, but I've never had a problem. But I have cera-metallic coated headers, to keep the under hood heat down.
http://shbox.com/1/harness.htm
Your 97 will be slightly different because of the added O2 sensors, CKP sensor and EVAP vacuum detection switch.
Just go to Summit and do a search on "heat wrap". You will find various size of sheets that can be cut to the required size.Fred
