Hey again guys,
I brought up a misfire issue I was having before in closed loop; after rewriting the PCM again to remain in open loop (for garage testing and tuning). I have been slowly getting rid of problems from the last owner of the car with a reasonable success
I noticed on a log my tps had a good deal of flat spots throughout the sensor range. I replaced it today since to get rid of the flat spots, and my misfire problem completely disappeared.
My question is, what effect does the tps have on closed loop operation?
I know that it controls your off idle closed throttle timing, but how is that factored in with the MAP vacuum values?
Thanks again guys
Thanks again guys
. engine is running much happier now. It did seem like there was a great deal of effect from tps input. Now I'm having issues with my idle returning back to the stopped value, e.g. it is sitting at 1200 rpm sometimes coming to a stop. My first suspect is the IAC valve, especially since the steps are going down along with that 5 degrees of spark retard for idle overspeed correction. I think that is more likely than an intermittent vacuum leak or something silly like that.
