Hey guys,
Here again with another issue with worldly physics.
I have my trans etc down for a clutch swap, the pilot bearing from before was of the brass bushing variety and wasn't properly lubed by the tech who did ithe last install; the entire inner section has completely work away, and due to heat, has 'welded' the outer section to the crankshaft. I have tried many different means to remove it, including filling the void behind and in the bearing with heavy grease and hammering a socket extension into the bearing to put a large amount of hydraulic pressure behind the bearing to lift it out. It looked like there *might* have been some of the pb blaster I applied squeezing out between the bearing and crankshaft section. I feel like I may be out of options here and need to step it up to a skill saw with a metal blade to take a longitudinal slice out of the bushing.
Any ideas?
-Al
Any ideas?
-Al
THe new bearing is going in with a good coating of silicone spray to ease the next installation.
