Engine began overheating. Removed last years new waterpump, and found the pump coupling splines had rusted out on the pump side, therefore not spinning the impeller. GM replacement was $42, very proud of that now adays. Replaced the waterpump with another lifetime warranty unity from NAPA.
Overheated - Interesting Part failure
A one-year-old water pump rusted that badly, that quickly? Why is there so much water on it? Maybe you need to dig a little deeper into where the water is coming from...2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
"Black, the fastest color"
300 k mi? Guess you can't blame GM too much for that, then.2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
How many times did you change the water pump, over the 316,000 mile life oof the engine? I'm having a bit of a disagreement with someone on another forum, who claims the LT1's are known for having water pumps that fail "early and often". I just haven't seen it reported as a problem any more frequently that any other engine.Originally posted by peteThe coupling rusted the splines out, it was the factory original, 16.5 years and 316k miles.Fred
I just replaced mine...first one in the life of the car...15 years and 153k miles. The pump never actually failed. One of the connecting aluminum tubes came out of the pump when I tried to remove the hose.'95 White Z28 M6 Cold air intake with K&N air filter, air foil, flowmaster cat-back, eaton posi, motive 4.10s, aluminum driveshaft, "skip shift" eliminator, '97 Z28 chrome wheels, hypertech programmed
I bought a new one at about 65,000 miles in 1999, not because the old one was bad, but because I wanted a new one for the stroker build. The new one has been in service for 10 years, but the car only has about 85,000 miles on it at this point.Fred
Original made it to 150k, next to 215K, next to 305K, latest to 315k but doesn't count.
The last two had 3/16" weep holes, so I didn't need to drill them out for the plastic elbow for the hose to keep coolant off the opti.The Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
