my t/a is down for repairs. will be a while before i can get $$ to finish. was looking to drain the fuel out of the tank. cant find anything in a repair manual that details it. the bulb siphon that i got at the auto parts store wont get into the tank thru the filler tube. anyone have any experience on how to drain the tank easily? thanks.
draining fuel tank
we used at a auto shop was a peice of rubber fuel line with a hole cut on the end and used compress air to start a vacuum to pull the fuel out other trick was we used we kept a weak but working fuel pump with a hose , put in the filler and let it pull the fuel out2009 Honda Civic EX- the daily beater
well problem is getting into the fuel tank past the filler. seems to be some sort of baffle at the end of the tube. guess i should of been more specific. but thanks for the compressed air idea. that does seem easy if i can get a tube into the tank- thanksprevious- '82 recaro. current-bone stock '02 t/a 6sp base model.
I did that until I figured out there is a 'test port' for the fuel pump... the little grey single wire connector near the pcm; just apply 12v and go, just dont cook your pumpOriginally posted by Joe 1320Remove the schrader valve from the fuel rail test port, hook up a rubber fuel line hose about 5-6 feet long. Turn the key to run and let the fuel pump empty the gas into spare 5 gallon gas cans.
-Alex
ZO6 wheels (clones)
With questionable guts:
Forged bottom end
pacesetter longtubes
K&N RAM air from 96 ws6
96? ws6 hood
96? ws6 spoiler
full emissions delete
Edelbrock IAS shocks
