My left turn signal has gone from working on occasion to not working at all. All of the bulbs work. All wiring appears to be in good shape. The brake lights and hazards work. When the hazards are on, it is dimmer on the left side. Specifically the left of the two bulbs that flash on that side. My Haynes manual says if it only effects one side then it is a faulty bulb and not a bad flasher.
Since I've owned the car (7yrs) the left turn signal has required more force than normal to use. It does still go into position, just won't flash or click on that side.
The manual does not offer a check for a bad Turn signal switch. Could I need a new turn signal switch? That is my suspicion, but I am hoping not to have to replace that.
