I was wondering if anybody have any tips and suggestions on what psi I should be running at the track and how much of a burn out do I have to do on the nittos? The nittos I have are on 16 x 8 stock trans am wheels. Any suggestions would be greatly apprecaited. Thanks.
Nittos
Nittos
Eric Lelina
95 Z28
Tuned by Carolina Auto Masters
302hp and 335tq
M6,GMPP CAI,1.6 Crane Gold RRs, MAC Headers,1LE intake elbow,Air Foil,!TB Bypass,Hypertech 160 Thermostat,Taylor Spiro-Pro 8mm Wires,Accel Super Coil,MSD 6al,SLP 2otl catback, Eibach Pro Kit,DMS SFCs,Hotchkis STB,BMR Adjustable PHR,Global West LCA,1LE Sway bars front and rear,KYB Gas-A-Just shocks, Energy Suspension Tranny Mount and Endlinks,Prothane Poly Torque Arm Mount,LS1 Driveshaft,17x9 SS rims.Tags: None
I run around 15 PSI and heat the heck out of them. Big Burnout. However, my sixty foot times still suck, but this is the best technique that I have found.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Is that an automatic? My six speed has a SPEC stage 3 clutch and there is no slip. I either bog the engine out of the hole or smoke the tires through first gear. My best is a 1.9 sixty footer. I didnt use any nitrous that run (i was out) and I should have, because it would have been the 11 sec. run I've been trying for. I mostly run 2.0 - 2.1 sixty footers. I need slicks.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Well, either im a sucky driver or that stage 3 clutch is killing me. I had a stage 2 clutch in the car prior to this and it would slip bad when banging 2 and 3 and it was a brand new clutch. The stage 3 doesnt slip at ALL but I think its killing my launch. I am running a 3:73 gear.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
I just wanted to say thanks guys for your help. I will post the results as soon as I get to the track. Again thanks for your help!Eric Lelina
95 Z28
302hp and 335tq
