Nittos
  • Nittos
    I was wondering if anybody have any tips and suggestions on what psi I should be running at the track and how much of a burn out do I have to do on the nittos? The nittos I have are on 16 x 8 stock trans am wheels. Any suggestions would be greatly apprecaited. Thanks.
    Eric Lelina
    95 Z28
    Tuned by Carolina Auto Masters
    302hp and 335tq
    M6,GMPP CAI,1.6 Crane Gold RRs, MAC Headers,1LE intake elbow,Air Foil,!TB Bypass,Hypertech 160 Thermostat,Taylor Spiro-Pro 8mm Wires,Accel Super Coil,MSD 6al,SLP 2otl catback, Eibach Pro Kit,DMS SFCs,Hotchkis STB,BMR Adjustable PHR,Global West LCA,1LE Sway bars front and rear,KYB Gas-A-Just shocks, Energy Suspension Tranny Mount and Endlinks,Prothane Poly Torque Arm Mount,LS1 Driveshaft,17x9 SS rims.
    I run around 15 PSI and heat the heck out of them. Big Burnout. However, my sixty foot times still suck, but this is the best technique that I have found.
      You have to find out what psi runs best with your combo. So far, the best pressure for my car is 20-22psi.
      I heat them up until I see smoke in the mirrors. Roll up to the line and go. Best so far is a 1.62.
      Rob
      04 GTO
        Is that an automatic? My six speed has a SPEC stage 3 clutch and there is no slip. I either bog the engine out of the hole or smoke the tires through first gear. My best is a 1.9 sixty footer. I didnt use any nitrous that run (i was out) and I should have, because it would have been the 11 sec. run I've been trying for. I mostly run 2.0 - 2.1 sixty footers. I need slicks.
          Yes, the TA is an automatic.
          When I had my 96 WS6, the best I cut on Nittos was 1.75. That was a 4.10, 6spd car. Ran 12.4@111.
          Rob
          04 GTO
            Well, either im a sucky driver or that stage 3 clutch is killing me. I had a stage 2 clutch in the car prior to this and it would slip bad when banging 2 and 3 and it was a brand new clutch. The stage 3 doesnt slip at ALL but I think its killing my launch. I am running a 3:73 gear.
              I just wanted to say thanks guys for your help. I will post the results as soon as I get to the track. Again thanks for your help!
              Eric Lelina
              95 Z28
              302hp and 335tq
