I have a 98 WS6 w/automatic that engages hard (lunges, slams, bangs, jumps, jerks, hits, pounds, surges or any other descriptive word) only when placing it in drive. Anyone know of a possible cause and solution?
Transmission issue?
Joe is probably right, food for thought; what about driveline slack? Anything on a reverse shift or is it only into drive?-Alex
ZO6 wheels (clones)
With questionable guts:
Forged bottom end
pacesetter longtubes
K&N RAM air from 96 ws6
96? ws6 hood
96? ws6 spoiler
full emissions delete
Edelbrock IAS shocks
I have issues with my transmission and was wondering if above diagnostics / recommendations apply to mine?
Everything works ok except shifting from 1st to 2nd. It shifts real hard, i.e. jerks the whole car even when driving of easy on the gas.
It has about 60k miles on it and I wonder if I need to replace the fluid? Is there a service recommendation?
Thanks.97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
It may sound stupid, but start with easy solutions... when was the last time YOU replaced the tranny filter? A clogged filter or debris going thru the valve body can mess with the check valves... all causing the tranny to bang in gears, hard shifts, etc So if you didn't personally watch someone else change your filter... well you never know. I belive since the 4l60e is a beefed up version of the 700r4, 1st and R are in the same clutch pack. I had a 700r4 work fine in 1-2 P and R, but when the clutch packs were taken out of the drums, it was 1st and 2nd that were f*cked up.My toys...
the Garage Queen - 2002 UltraZ Camaro
The DD- 1998 T/A WS6 clone with LS6 top end
The Long project - 1985 Z28 383 POWER 10sec 1/4
The off road toy - 1988 1500 Sierra 4x4
