thought you might find this interesting........
dont know if you know Mike A. or not. he's an old bud of mine. we founded the CompTA owners assoc. together..anyway... he just broke into the 10's..........this is a list of his mods.:
For those who have asked here is the current modification's for Comp T/A #57.
STOCK PARTS:
engine
cam
tuning
transmission
torque converter
rear end with 3.23 gears
panhard bar
cat back exhaust
FREE MODS:
1LE Alum. drive shaft
Removed screen from MAF
Bypassed coolant from flowing through throttle body.
Removed EGR system
Removed air pump
Opened up hood scoop baffle
Removed louvers from air box
Fan switch
Torque Converter lock up switch
Engine Tie Down Torque Strap
BOLT ONS:
LT4 Cylinder Heads
LT4 Intake
1.6 Roller Rocker Arms
Jet Hot Long Tube Headers 1 3/4"
Mufflex Y-Pipe with cutout
Polished LPE 52mm Throttle Body with air foil and plate
NGK TR6 spark plugs (gapped .035)
160 degree thermostat
LT4 Knock Module
MSD 6A
MSD coil
MSD spark plug wires
Adj. Fuel Pressure regulator
K & N air filter
Under drive pulley
SVO 24lb Fuel Injectors
Meziere Electric Water Pump
Hypertech (for fans)
LPE Billet Alum. valve covers (polished) with breather
NITROUS:
Nitrous NOS #5176 (125hp jets) Dry system Hidden 1200psi bottle pressure
Progressive controller (100% on @.5 seconds)
Remote On/Off bottle valve
Bottle heater
Bottle blanket
Nitrous pressure gauge
Billet nitrous filter
100 octane unleaded racing gas.
SUSPENSION:
Spohn Adj. Torque Arm with driveshaft loop (set @ -2 degrees)
QA1 adj. Front Shocks with V6 springs (set @ #1)
QA1 adj. Rear Shocks (set @ #4)
LCA Relocation Brackets and Poly Bushings (middle setting)
Boxed lower control arms
Sub Frame Connectors
Strut tower brace
BFG Comp T/A 275/40/17 drag radials
Air bag passenger side rear 20psi
Drilled and slotted brake rotors
So far I have spent $8,000
Mike Alford
Comp T/A #57
10.89@128mph with 1.47 60ft
6.89@100mph 1/8 mile
High Performance Pontiac Magazine "Cover Car" 2/2000
STOCK PARTS:
engine
cam
tuning
transmission
torque converter
panhard bar
cat back exhaust
FREE MODS:
Removed EGR system
Removed air pump
Fan switch
BOLT ONS:
LT4 Cylinder Heads
LT4 Intake
LT4 Knock Module
MSD 6A
MSD coil
K & N air filter
Under drive pulley
NITROUS:
Bottle heater
Bottle blanket
SUSPENSION:
Strut tower brace
Mike Alford
Comp T/A #57
