I understand a decent amount about breaks the only thing I don't get is ABS. My friend asked me to take a look at his 91 explorer because it has a light flashing on once in a while that says rear ABS inop. (or something like that). I've driven it and they seem fine. I even kicked on the ABS in the snow this past weekend and they worked good. Is this just a faulty sensor or what else should I be looking for.
NFB ABS on an Explorer
if you know brakes...then you have to learn to spell it right.........hahahahahahaahahahahahaha (j/K)
sounds like a sensor thing to me... if i remember correctly, the Exploader.......er..Exployer.. had some TSB's to that effect.
back when abs first came out..alot of trucks got rear abs only... i was thrown by the light then you mentioned..for abs systems dont have a seperate light for front and rear, that im aware of... this vehicle may be a rear abs only.
Same here
It's the sensor. It's located over the axle in the rear near the pumpkin. It was cheap but I had to go to the dealer,
of the usual stores had it, not sure why (since it was so common to fail). Changed mine about two months ago, and the light went away.
NBM '02 Z, SLP Lid, Corsa Cat-Back
(SOLD 07/03/2004)
breaks...sorry must have been around exhaust fumes to long lol. Yeah his is only the rear ABS. Not sure why they'd do that though cause wouldn't that make rear braking very limited if you had to pump them cause the front were sliding? Thanks for the help i'll put on a new sensor and see if that clears it up.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
