I peeled the pinstriping off of my Z and there is some glue residue left. What would be the best thing to use to remove it without damaging the paint. I was thinking goo gone or something along those lines. Also I think there is an item designed to help remove vinyl, don't know the name but would that work? All help will be greatly apreciated. Thanks in advance to the F-bod Gurus........Later
Pin Stripe Glue remover?
Almost any label and sticker remover will not mess up your paint job...
As you know, my hobby is detailing and I put a full body length dragon decal on my celica and before I traded it, I removed it with a can of "professional Strength Label and Sticker Remover" that I purchased a my local Advance Auto Parts store...
But on most label and sticker removers, the Warning area or the directions will say "Label & sticker remover will not harm most surfaces, but it is recommended before using..." quoted from the can I have of that label remover...
But like they say just try it on a small, small, small, pick hole size area first to see if it has any adverse reactions... But most products shouldn't harm the paint...Thanks
MaraSport
rubbing alcohol will not harm clear coat.
goo gone or whatever the name is wont either.
should do it.
if not...try some body clay. zaino is the best..... or clay majic from pep boys. carefully.
