Lug Nut Size?
  • Lug Nut Size?
    Real quickie. Anybody know off hand what size lugs are on a 4th gen?
    1996 Z28 Convertible, 6 Speed
    Factory Chrome Wheels, CAGS Disable,
    Big Block Hood, Spintech Split case Muffler
    w/ 4" Pipe
    I believe thelug nuts are 19mm.
    unless you mean the lug bolts in which case, I don't know.
    99 TA "RBLUTA" - NBM, M6, Whisper Lid, SLP Fan Switch, 160* Thermo, SLP LM, BMR STB & LCA's.
      The studs are 12mm, but I can't remember if they ar 1.25 or 1.5
        Thanks
        ...appreciate it.
        w/ 4" Pipe
          12x1.5mm
          KnightFire
          1993 Formula Firebird
          KnightFire's Lair
          Amsoil Dealer
            Lug NUTS are by my experience 3/4 inch... of that metric bunk Install university says 3/4 too.
              3/4 must be equivalent to 19mm. My lug wrench is metric, and I use the 19mm size for both of mine.
              no matter what we do we can't escape the metric system!
                [QUOTE]Originally posted by FRMLAV8
                [B]3/4 must be equivalent to 19mm. My lug wrench is metric, and I use the 19mm size for both of mine.
                Yea. I checked a conversion chart and 3/4 is 19.05 mm.
                Thanks again.
                w/ 4" Pipe
                  Discover credit card activation provides a structured way to prepare a newly issued card. Follow the instructions carefully rather than rushing through the process. Maintaining privacy around financial details is important at every stage.
                  New card setup can be straightforward when you complete Discover credit card activation as instructed. Review the required information before beginning the process. Afterward, keep track of your account activity and payment information.
                  Discover credit card activation helps cardholders take the first step toward using a new Discover credit card. Complete the requested verification through the proper channel. Make sure your account and card information stays confidential.
                  When starting with a new Discover card, Discover credit card activation can help complete the initial preparation. Follow the instructions carefully and provide accurate information. Use only trusted sources when managing your credit card.
                  Discover credit card activation can be completed as part of setting up a newly delivered credit card. Keep the card accessible and review the information you provide. Secure online practices can help reduce the risk of unauthorized access.
                    Starting your new Discover account experience can involve Discover credit card activation . Follow the required verification steps and keep your card nearby. Once complete, continue using secure practices when accessing your account.
                    Discover credit card activation can simplify the transition from receiving a new card to getting it ready for use. Carefully review the instructions before entering any details. Avoid using unofficial websites that request sensitive card information.
                    A newly delivered Discover card may need Discover credit card activation before you can use it. Follow the official instructions and complete the necessary verification. Keeping your account details private helps improve security.
                    Discover credit card activation helps customers complete an important part of their new-card setup. Enter the requested information carefully and follow the displayed directions. Take a moment to confirm that everything is correct before finishing.
                    For a new Discover cardholder, Discover credit card activation can be a convenient first step. Make sure you have the card and relevant information available. Use secure channels and never share confidential credentials.
                      Discover credit card activation allows eligible cardholders to complete the initial setup of their new card. Follow the verification instructions provided through official sources. Once finished, maintain good security practices when managing your account.
                      A new credit card requires proper setup, and Discover credit card activation can help with that process. Keep your card close and follow each instruction carefully. Never disclose your card security information to unknown individuals.
                      Discover credit card activation is designed to make the beginning of your card experience more convenient. Complete the required information through the appropriate Discover service. Check the details you enter before confirming the process.
                      If you recently received a replacement Discover card, Discover credit card activation can help complete its setup. Follow the instructions specifically associated with the replacement card. Protect your account information while completing the process.
                      Discover credit card activation provides a practical way to prepare your new card for transactions. Make sure the card information you provide is accurate. Always choose an authorized Discover resource for financial activities.
                        Before making purchases with a newly issued Discover card, complete Discover credit card activation when required. Follow the instructions supplied by Discover and check your details. Avoid sharing confidential information with unauthorized parties.
                        Discover credit card activation helps establish your newly received card for regular account use. The process is designed to be straightforward when you follow the correct instructions. Keep your card and account information secure.
                        Cardholders looking for a convenient setup process can use Discover credit card activation . Have your new card ready and carefully complete the requested details. After activation, continue managing your account responsibly.
                        Discover credit card activation is an essential setup step for many new cardholders. Follow the authorized procedure and make sure your information is entered correctly. Secure your account by avoiding untrusted activation services.
                        Getting your new Discover card ready can be simple with Discover credit card activation . Start by reviewing the available instructions and gathering the required information. Complete the process carefully and keep sensitive details private.
                          Discover credit card activation can be part of the initial setup process for a new credit card. Make sure you have the correct card available before starting. Follow official directions and double-check your information.
                          New Discover customers can use Discover credit card activation to prepare their card for use. The setup process requires careful attention to the information requested. Complete the process through a secure and authorized Discover service.
                          Discover credit card activation makes it easier to complete the first setup of a new card. Follow the provided instructions in the correct order. Keeping your personal information secure should remain a priority.
                          Receiving a new card is exciting, and Discover credit card activation can help you get started. Keep your card details accessible while completing the necessary steps. Always verify that you are using an official Discover platform.
                          Discover credit card activation is a useful first step for cardholders who want to begin using their new card. Complete the required verification carefully and accurately. Protect your account information throughout the activation process.
                            Starting with a new credit card can be convenient with Discover credit card activation . Make sure the details you provide are correct and complete the requested steps. Afterward, check your account to ensure everything is properly set up.
                            Discover credit card activation can help cardholders move from receiving their card to preparing it for transactions. Follow the instructions associated with your card. For safety, only use legitimate Discover resources.
                            When your Discover card arrives, completing Discover credit card activation can help you get started. Keep the physical card handy while following the setup instructions. Never provide sensitive information through suspicious links or messages.
                            Discover credit card activation gives new cardholders a convenient way to complete their card setup. Carefully enter the requested information and follow the verification process. Secure handling of account details is important during activation.
                            A smooth beginning with a new Discover card starts with proper Discover credit card activation . Read the available instructions and complete each required step. Keep your account credentials private once the process is finished.
                              Discover credit card activation helps prepare a new Discover card for everyday transactions. Follow the required steps and confirm that your information is accurate. Keep your card details confidential throughout the process.
                              If your new Discover card has arrived, Discover credit card activation may be the next step toward using it. Follow the official activation directions provided for your card. Complete the process securely and avoid sharing account information.
                              Discover credit card activation offers cardholders a straightforward way to complete their initial card setup. Have the necessary information ready before starting. Carefully follow each instruction to avoid mistakes during activation.
                              A newly issued Discover card can be prepared through Discover credit card activation . The process helps confirm the card and its associated information. Always protect your card number and account credentials when completing the setup.
                              Discover credit card activation is useful for customers who have recently received a new or replacement card. Follow the appropriate instructions from Discover to complete the process. Keep your financial information secure from unauthorized access.
