I've noticed (am a newbie) no MAF setup on my induction, what is the difference between 93' and 94+ fbodys, and advantages or disadvantages of having or not having the MAF.
93' Induction?
The basic difference is that the 93 is a speed/density system using the MAP sensor to guage engine load rather than the MAF. Simply put, speed density measures load by measuring vacuum (with the MAP), air intake temp, rpm, and throttle position to detemine injector pulse width and spark curve. MAF measure the amount of incoming air through the MAF meter to measure load.
I have never modded a speed density f-body, but from what I hear, they are not as compatible (with stock tuning) to major mods as their MAF brothers are. However, one benefit is that they do not have the inlet restriction of the MAF meter. So, with the right research, parts and tuning, they can be built to GO.
Im sure some of the other guys can add on to this.......96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
11.6 @ 123mph (1.6 60' - getting there)
Its not that you wouldnt notice a difference, but when adding things like new heads or cam (dramatically changing the aiflow into the engine) the PCM might not recognize whats happening (because your not measuring airflow like in a MAF car) and the car may not be supplied with the right amount of fuel or advance etc.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
I try to be helpful96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
