While I'm installing the cam and heads should I remove the air pump and EGR systems? I hear differing stories as to what will happen. like clogged cat and oil leaks to nothing will happen to it will run better. I figure that I only put about 1500 miles on the car cruising and problaly 30-40 1/4 mile passes a year so If I don't need them and they take up room in the engine bay why not take that junk out? If I remove them will I need to program them out or will they not affect the PCM?
Thanks
Skip
Thanks
Skip
