Hey N20LT4Bird you said earlier you couldn't weld the torque arm bracket to the iron housing. I was wondering why you couldn't TIG weld a bracket to the pumpkin. I do some TIG welding for work.
Anybody know the axle width.......
fastTa -
Can you tig weld a steel bracket to cast iron??? I do not have access to a TIG, so I do not know a lot about it. If you can TIG it, that would make my problem a lot easier to solve - I could just send it out and have it welded.
Yes you can TIG iron and steel together and it is actually a stronger weld than a "steel to steel" weld because of the alloy that is formed by combining the two metals
I guess I will have to look into this then.......thanks.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
