Wondering if anyone here knows the stock axle width on a 4th gen???
Anybody know the axle width.......
Tags: None
fastTa -
Thanks.
Are you going to be doing your own spring perches, shock brackets, LCA brackets, and panhard bracket on the axle housings?
Yes, I am buying another f-body housing to do measurements, and then I will be cutting and pasting the bracketry. The torque arm bracketry will be the hardest as you cant weld to the cast iron pumpkin housing. I've got a few sketches of a bracket that will be welded to the axle tube and u-bolted to the housing though. We'll see how it goes
Go to the Strange Engineering
website, and look up the 12-bolt for the 3rd/4th Gen cars. They have a dimensioned drawing, and they use the stock attachment brackets. Page 65 in the catalog.Fred
NICE!!!!! Thanks Fred, that drawing will be very helpful.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
That indeed is a good diagram, I just wish it was bigger and easier to read. I signed up for a new catalog so hopefully it will be easier to read in the actual catalog.
Hey N20LT4Bird did you already find a stock 10 bolt?
Yea - i ordered a catalog too.
No - i havent bought the rearend yet. I have talked to Billy Graham @ Billy G's f-body salvage and he said he could ship me just a housing to my door for 125 or so. I will probably order it up next week.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
fastTa -
fastTA - I see in your mods that you have a custom 9" rear. Did you build it or buy it from moser or someone else? If you built it, what did you do for the torque arm mounts?
P.S. - Nice ride. What does that thing run in the quarter??96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
The complete aluminum center section and spool are from Strange Engineering. I am doing the same thing you are doing right now and welding on my own bracketry to the axle housings. I ordered the torque arm bracket already on the pumpkin, luckily
This car has not even seen the track yet believe it or not. My previous hydraulic roller setup with 233/239 CC ran wicked fast on the street but never had time for the track, so after only 2 months I decided to really get serious with the car. The block is being converted to a spalyed 4 bolt right now. So as soon as that is finished, we can start putting the motor back together again. Raceweight should be about 2830. It should a fun ride!
If you dont mind me asking, what did you pay for the 9" center section???96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
I got lucky and bought it used from a friend for $550. So it looks like I will be able to save about $1000 doing the rear end myself
after all said and done. Keep us posted on how you are coming and I will do the same
Thats a good deal on the housing. Thats my plan too - to save about a grand. I think I can do it if my torque arm bracket works. I'll keep you updated - its should be done by spring.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
