Mileage
  • #16
    Originally posted by mirroredshades:
    Is this something I can do? I have more time than money right now.
    This has to be done with specialized equipment. But worth the money
    Originally posted by Joe K. 96 Zeee!!:
    Just curious, but had you tried a fuel injector cleaner prior to that? I use some about every other oil change.
    Yeah, I used Chevron Techron. I just did alot of stop and go driving which with our emissions systems is very bad as far as heat hardened deposits.
    • #17
      Maybe i need to get my fuel injectors cleaned seeing at how low my mileage is compared to most.
      ______________________________
      94 Camaro Z28 T56
      • #18
        I get about 200 to the tank in mine ... shes only got 35 k on her too
        -Nick-
        95 A4 Z28
        • #19
          i dont know why but i get about 220 miles to the tank thats wrong with my car its a 97 lt1 so its about15 mpg ON HIGHWAY!!
          i have thestock rear end on an M6 just wonderin
          thanks
          1997 Camaro, Z-28, 5.7, Manual 6, K&N cold air intake, custom ram air scoop, ported MAF, Resonator plug, air foil, 160 thermostat, hypertech power programer 3, 3 inch cat-back exhaust, strut tower brace, K&N valve breather, centerforce dual friction clutch, slp short throw shifter, TNL short stick, O2 simulators, Next mod will be 1.6 rockers, pushrods, and springs. any reccomendations?
          • #20
            I get about 200 to a tank but she ain't exactly stock. I think I need to have the PCM reprogrammed.
            Kbddsfc,B&M Ripper,Ws6 Rims,Hotchkiss Stb,Bmr Lca,Gwphr,Strange 4:10's,LPEds,Borla,AS&M Headers,RT cat,Powerslot rotors,Hawk Pads R/Pf pads Fr,Mba shift knob,Slp Hood&Airbox,Holley Powershot filter,Fernco mod, Lt4km,Firebat decals,T/A Girdle,HPP.160stat,Bilstein shocks,Z06 Brakes,AFS ZR1's,GSD3's.
            • #21
              The last long road trip (to Bowling Green :-) ) got me about 27-29 mpg highway. The stop and go stuff gets me about 18 or so.
              65K on the clock. 95 M6 T/A
              -Paul
              WickedLT1's Home on the Web - Wicked Pictures
              95 - Trans Am - LT1 - 6Speed
              Car Status: Hmm, winter projects coming up...
              • #22
                Damn .. I am getting 160miles from the gas tank these days, its been cold here, and I drive around mostly in the city, i do about 10 miles high way driving each day. So this cant be right guys, am getting 10-11 miles to a gallon ??? I always reset the the dial evrytime I go pump gas. In the summer average I was getting 190miles. hmm..
                1993 TA SOLD
                • #23
                  i dont know what im getting yet. im thinking about 10 until i put 373 or 410's in, then probably 8 or less. damn carburetors!. my riv gets about 22 and my blazer gets about 15 (damn tbi) , but i do a lot of city driving. by far, the best fuel injector cleaner is bg44k.
                  86 Camaro (350)
                  79 Blazer (FI 350)
                  98 Buick Riviera (S/C)
                  96 Grand Prix (Sp. Ed.)
                  • #24
                    Do you have the stock gears or did you swap them out? Running a different cam? Something else major?
                    I'd say it's certainly possible to get milage like that, but you'd have to be idling the car a lot, heavy on the gas, or a combination of the two.
                    Are you using high octane? Have you tried fuel injector cleaner? It helps. I used it on my V6 after 35,000 miles and there was a definite, noticable difference. You can't rely on the cleaner in the gas.
                    My absolute worst city milage with the 3.42 gears in has been 17mpg.
                    Joe K.
                    '11 BMW 328i
                    '10 Matrix S AWD
                    • #25
                      All I do is Highway Driving...then again, if you live in Atlanta (close enough to claim Atlanta)...all you do is drive on the highway. Me personally...I've seen 27 mpg. But I hover around 23-25 all day.
                      I always fill my gas tank up when it hits the 1/4 left mark, and it ranges from 150-250 miles per fill up depending on whether or not I drove up to towncenter a couple times or not.
                      Live 3 miles from work but it still takes 15 minutes to get there, pretty much all of it stop and go. But thats cause I live *in* atlanta... not 30 miles outside of it.
                      I find it funny however that I can get to pretty much any part of downtown, midtown, buckhead, the highlands, or ansley park in about 15 minutes or less... but it takes me 30+ minutes to get anywhere noteworthy OUTside atlanta?
                      Atlanta's not the problem... its the mf'ing suburbs that screw everything up.
                      ps dj taso, i like your sig picture... once my ws6 hood gets here i'm gonna rip you off hardcore and do the same thing
                      • #26
                        As far as i know the car is completely stock, hmm excessive idling not really, i step on it once in a while but WOT is rare, I used to get a fuel odor coming from driver side rear wheel during the summer when idling after the car warmed up or when coming to a stop. ALways use 92 or higher, Ill give the fuel injector cleaner a try.. thanks
                        1993 TA SOLD
                        • #27
                          My car gets 23 on the highway and uses a lot more gas around town, but I don't know how much.
                          • #28
                            Wow, it sounds like a bunch of us LT1 guys are getting crappy milage. I once ran an entire tank out in 6th gear and I got 20. I need to get my fuel system checked out but dang, money is pooring out of me like a sieve. Everything I own needs something.
                            96 TA Sold!
                            87 TA Sold!
                            80 Z28 Sold!
                            74 Formula Sold!
                            73 Z28 Sold!
                            69 Camaro Not Sold!
                            • #29
                              Sometimes I feel that way too. All of my little mechanical children are sucking the life out of me - they are always needful of new parts or batteries or fluids or TLC time. There's a lot of people that think I'm nutz and I can remember one time when I had 2 cars & 2 bikes (like now ) and nothing was running, so had to bum a ride to the parts store to get something running...
