no vibration when i brake.. only when crusing at certain speeds above 60 the steering wheel and front end vibrates . wheels out of balance maybe?
Front end vibration after new rotor and brakes
87pontiacTATags: None
Re: Front end vibration after new rotor and brakes
sounds like tire balance to me. just weird that it would do it right after new rotors and brakes.Originally posted by 87pontiacTA
87pontiacTA
yeah...
yeah i know.. but then again coincidentally it has been real rough out here with the snow and ice and potholes and stuff... im goin after work to the shop to have em check the balance..
Hmmm
Did you scrub the mounting surface real well when you put the new rotors on? I usually take a wire wheel and dress up the surface a bit to make sure that the rotor sits flat and true on the pad, otherwise you will throw the rotating assembly out of balance. Wheel weights won't fix this one.
-Paul
WickedLT1's Home on the Web - Wicked Pictures
95 - Trans Am - LT1 - 6Speed
Car Status: Hmm, winter projects coming up...
Are the lug nuts tight.
I had a Cutless Supreme Int. and everytime I had the front wheels removed for work I noticed vibration and noise a day later.
Everytime it turned out that the nuts weren't tight enough. Never found out why that was though.97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
87pontiacTA
Thanks for the input guys much appreciated.. went and got 2 new tires today and that solved the problem.. they were kinda shot.. im going for an allignment today.. the wheel is a little off and it pulls slightly.. again thanks!
