How big of a shot are you spraying?
Question for all the N20 junkies.
fastTaTags: None
just 100 horse.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
fastTa -
70 on what kind of bike?Originally posted by MN6WS6
125 shot on the car
70 on the bike
Yes, I'm insane, but sometimes I forget the medication
I want to get another fuel pump before I go any bigger. I am pushing it as it is on the stock pump. But yes, after the differential and slicks, its going to be a high volume fuel pump and a 175 shot.Originally posted by fastTA
N20LT4Bird, do you plan on going any bigger than 100 with your new setup?96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
I think I am going to start at 175 and gradually throw in bigger jets until I get to around 275. I don't think I really want to push it that much but I think 275 on top of a 700+ hp motor and a race weight of around 2800 lbs should make for an interesting ride!
Not too shabby. I'll race you in my Dodge Omni.Originally posted by fastTA
That would be cool!Originally posted by N20LT4Bird
Hey N2OLT4BRD how is your rear end bracketry coming?
