in an automatic LT1 should i just flow it off the take off at the strip or brake torque to the rpms right b4 the wheels start turning and then floor it?
in an automaitc how to launch at the track?
Usually guys just hold the brake with their left foot, bring the RPM's up as much as the convertor will allow and then give it the gas on the 3rd amber. Feather it in until you feel it bite and then floor it.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Do you have an aftermarket TC? If so which one? What stall?
I find I get my best launches if I hold her to about 1200 RPMs (just to pre-load the DS and rear) and flash the converter on the 3rd amber. I switch up between the foot brake and line loc off the line. I manually shift mine, but with the 4L60E your best off leaving it in 3rd the entire trip down the lane.
KnightFire
whats................an "automatic"..????????????
an automatic will beat a 6 speed stop light to stop light any day of the week.............
